BillAlex
Just dropped a 5.4L 3V from Promar that I bought for $2,999. I did a ton of research and nothing but horror stories or rolling the dice at buying a used engine from a Junk Yard. Promar puts out one hell of an engine and if you look into the equipment it takes to rebuild one of these beast correctly, you realize it can easily take a quarter of a million dollars worth of equipment to reman an engine. The biggest selling point that Promar has is using OEM Ford phasers and timing chain. It seems that the 5.4L 3V is notorious for eating chain guides, clogging up oil pumps and pretty much trashing an engine if let go to long.
In addition to dropping 3 Grand on a Reman engine, you need to invest another Thousand in preventative stuff when it's all apart. I would also go with Ford OEM on things like Water Pump, upper and lower Radiator hoses, Serpentine Belt, Heater Hose, new updated triple platinum plugs, Variable Timing Chain Solenoids, etc. I dropped a new Radiator as what the hell, it's probably at least 10 years old by the time you rebuild an engine, so spend some extra time and money making sure the cooling is up to par. It's actually cheaper to buy a new radiator from Rock Auto than it is to flush one at the local radiator shop. Some go for the Heater core but mine looked good so I went with new OEM heater hoses. Fluids of course need to be replaced as well as Thermostat. All these things add up not to mentioned last minute gaskets that seem to have walked away. No one tells you about the extra stuff you should be doing when you order out a Reman engine.
If you decide to go local machine shops for your rebuild, be very careful. I checked with our local Better Business Bureau and was shocked at the number of complaints that found "used" pistons or rods in the rebuild engine. Some of these guys try to save a buck and end up putting back anything that didn't break or was shinning. Some very large customers like U-Haul actually tore a brand new reman apart because to many engines were failing. They found only two new pistons and rods in a 8 cylinder engine and that was the end of that contract. No matter what you do or who you go with, get references of "happy customers". Mandatory!
Finally, Engine R&R is not rocket science. I had my toilet clogged over the week end and the Plummer charged me $250. and it took him less than 15 minutes to unclog it. I was a little pissed and told him I am a CPA with a Masters Degree and I only charge $200 per hour. He told me "yeah, I know. When I was a CPA, I only made $200 an hour also". No matter what these guys tell you, changing an engine out can only go one way. You turn a wrench in one direction and not much difference between MAC tools, Snap on and Craftsman except the price of the tools. Book rate calls for about 15 hours give or take a couple and I find it difficult to be paying the kid we used to pull down his pants in school $120 per hour (that works out to $240,000 per year for a 40 hr. work week!). Shop around. You are not going to convince me that a high school drop out is worth a Quarter of a Million dollars per year. (Unless of course, his name is Bill Gates). I can assure you that a $40 to $50 per hour (shop rate) engine will run just as well as a dealership mechanic that charges $120. per hour shop rate. Sure, there are bad people in every profession but I have found some really good ones on Craigslist. Don't sell them short if they quote you $35 to $40 per hour. Did you ever think of how much a Dealership mechanic makes that gets 30 to 35% of the bill? Some of these guys work week-ends on the side and charge much less than you would pay at your local garage. Don't be afraid to look around. My mechanic, who loves me during tax season, quoted $2,200 in labor to R&R a Reman Engine. I paid $700 to a mechanic that worked out of his home and has 17 years experience with lots of letters from "happy customers". Shop it. That alone can pay for a first class Reman as opposed to a cobbled together one with used parts.
