Maddog11
Well I am having an issue with my trans, that only has approx 50k miles on it since being replaced by Ford, where it will neutral out going into overdrive. So anyway I was removing the valve body and as I brought it down the 2-3 piston came down with it. My questions are, is this normal? Also, does this piston use a snap ring to hold it in place like the overdrive piston does?
On a side note I did find the piece of the snap from the overdrive piston jammed in the valve body which was preventing it from going into overdrive.
