Replacement Shocks and Coil Springs for 2006 Expedition (4WD, Coil Suspension)
MC_PL
Warsaw, Poland
Hi everyone,
I’m looking to replace the shock and coil spring assemblies (both front and rear) on my 2006 Ford Expedition. It’s a 4WD model with factory-installed coil spring suspension. The OEM shocks and springs have held up well over 107k miles and still provide a stable ride, but they’re showing significant corrosion. I’d like to replace them before any leaks or failures occur.
I came across a set of Monroe Quick-Strut assemblies that look promising, but I’ve read conflicting information online. Some sources suggest these assemblies are specifically designed for air-to-coil spring conversions, and there might be bolt spacing issues for my factory coil suspension setup. Since I don’t live in the U.S., shipping costs for four assemblies are quite high, so I want to ensure they’ll fit before ordering to avoid unnecessary expenses.
Here are the part numbers I’m considering:
  • MONROE 171369 Quick-Strut (Front)
  • MONROE 171370 Quick-Strut (Rear)
Can anyone confirm if these will fit a 2006 4WD Expedition with factory coil spring suspension?
Also, I’m curious about the quality of Monroe products. Are they a good choice for durability and performance, or should I consider a stronger alternative?
Thanks in advance for your help!
Cheers,
MC
whtbronco
Winchester, VA
I don't believe there is a bolt spacing difference in the Gen 2 model(2003-2006) between the coil and air spring mounts. They'd have to replace the mounts that are welded to the frame to have different spacing. I used the Rancho Quicklift struts to replace my 2004 air suspension, even though Rancho, now owned by Monroe, says they won't fit. They fit just fine. I don't think I got any lift in front. I have a normal rake in the rear, about a 3/4" of lift as I recall the air springs sit level.
I have used Rancho suspension on all my trucks for over 30yrs and I love that I can adjust them. Soften them for road trips, tighten them up for around town handling, and crank them all way up when towing.
The Monroe Quick-Struts listed on RockAuto note that they fit both coil and air spring trucks.
Fits Front; Front Coil springs
or Front; Front Air springs; Converts Air Spring to Coil Spring Suspension; Requires Monroe Part # 90015C
Despite my experience noted below for this price I'd try the Monroe's especially since shipping is gonna cost you. If you're ordering from the US, you can get a full set of Monroe now for $254 plus shipping. I would personally avoid the Monroe RoadMatic series, the QuickStruts are certainly better.
I used to buy only Monroe shocks and struts for stock vehicles. The last few times I have been less than impressed with the Monroe brand. The last 2 sets had 1 or more struts that squeaked and drove me nuts until I replaced the upper mounts. That was both on GM W body cars though. I have found KYB and Bilstein to be a little better. None of that experience is on the Expedition though. I swapped my Expedition's air springs at 160k miles for the Rancho struts and then replaced them again under warranty at 290k due to the lower mount bushings being crushed.
Member Recommended
bobbymorning
