Reset Mirrors Command?
Password
Is there a command or function that will reset the side view mirrors? A few years ago the dealer reset the mirrors when the settings would not save, and the mirrors would not go to the position they were set to. It's either happening again on its own or it's because my passenger mirror assembly was replaced.
Mr Big
Tampa Bay, Florida USA
To reset the power-fold feature, use the power-folding mirror control to fold and unfold the mirrors. You may hear a loud noise as you reset the power-folding mirrors. This sound is normal. Repeat this process as needed each time the mirrors are manually folded. Then use the memory number to save, once re-adjusted.
Password
Password
My issue is not the power fold function (at least I think it's not), it's the memory position of the actual mirror. Is the mirror out of position because of a power fold issue?
Mr Big
I'm not sure what your problem is.
However, if your vehicle has the memory mirror feature that goes with seat, steering wheel, pedals, do the following. Set the mirror position, and anything else you want to set. Then press and hold the seat number button. This saves the positions of the seat, mirrors, pedals, and steering wheel.
