Factory amp and sub
Thanks for the info, I'll check it out.
Here's solution to the sub I posted in another thread. It absolutely works and sounds amazing:
So searching the web near and far there is VERY little info on how to do this. The 2005 with factory nav does not have the same harness as the models without factory nave and therefore the 70-5521 harness with the addition RCA plug does not fit. You will actiall need the harness for older fords, thats easy to find, and crutchfield will get you that one. They are fully aware of this anomaly.
The hard part is hooking up the factory subwoofer through the factory amp. Here's the scoop:
Find the 12 pin plug with 4 wires in it. There is another plug that actually reads "AMP" on the top of it. That is NOT the right one. Pin out for that plug is as follows:
BN/OG: + speaker input (Only one RCA plug is required from the back of your HU. Tape off the white one if you have two. This is where you hook up the positive input or red wire from your line converter)
RD/BK: - speaker input (See above. Use the negative or black wire from same RCA)
BK: wire shield??? (I just hooked this up to ground, but I feel its not necessary)
DG/VT: Enable input (Hook up the AMP turn on wire from your HU here)
That's it! Bass is booming now! Feel free to ask questions, I got answers! Spent two days researching and testing this to find this pin out so hopefully I have paid it forward a little here. Good luck!
Helpful link but keep in mind you may have to use the one listed as not having factory nav: | Repair Guides | Entertainment Systems (2005) | Audio System | AutoZone.com
