Hi everyone! This is my first post on this forum, and also my first time owning an expedition. Back in January I purchased a 2019 expedition limited with 143k miles. I am now at 155k. I did get this truck for relatively cheap since I knew it at least needed updated cam phasers installed at the time of purchase, as well as new tires (they were mismatched). Initially after paying a local shop to fix those issues (along with some other minor things, including alignment and balance of my brand new Michelin defenders), the truck was great. And overall I've been super happy with it over the last 10 thousand miles. However...
Overtime, the truck has developed this buzzy vibration in the floor and steering wheel that is especially noticeable on a smooth road at 70+ mph. This is accompanied by a low growl coming from somewhere underneath the truck. If I put it in 4A, the noise and vibration gets significantly worse, but even in 2wd the vibration is bad enough to make my foot feel like its falling asleep on the gas pedal. So, I took it to my local shop and had it looked at. They put it on a lift and determined that my front right wheel bearing was noisy. They also said they noticed that the vibrations go away when turning side to side. Anyway, I authorized a new wheel bearing and the shop said they thought it was quieter afterward. $709 later (part of this cost was from them taking apart and inspecting the front differential, which they said looked fine) I take the truck for a drive and it sounds EXACTLY the same. No noticeable difference. The 2015 ford edge loaner they gave me to drive was smooth as butter all they way through 80 mph. Zero vibrations or shakes. My parents 2022 expedition max is also super smooth. Meanwhile mine feels and sounds like I have big aggressive mudders on it.
I currently have my truck back but this vibration is driving me insane, and I feel like the money I spent was wasted. The shop gave me a quote to take off the front driveshaft and inspect the differential bearings. I'm struggling to see how turning side to side could affect the noise if it was coming from the differential bearings. I guess I'm just wondering if anyone can point me in the right direction here? I know there are lots of threads on the expedition and f-150 forums about this, but most of them seem to be wheel and tire problems. My tires were just rotated so I don't believe it is that. Thanks in advance everyone!
Update 10/10/26: I replaced the drivers side hub assembly myself. Vibration and noise is still present. I took a 50 mile drive to test it out and noticed that at one point on the highway, the vibration just... stopped. Ubruptly. I was just cruising at 80-90 mph and didn't change anything, but I noticed right away.
Update 10/15/26: Took it back to the shop and had them look at the truck on a lift. They said the front driveshaft was spinning a little even in 2wd mode, as I expected. This is from some internal friction in the transfercase and is normal on a 4A system. They then removed the front driveshaft. I have yet to drive it but they confidently told me that now, when the front IWEs disengage, the noise goes away completely. They quoted me 1700 installed for a used front differential. I'm going to pick up the truck and drive it without a front driveshaft for the weekend before I do anything else.
Update 10/15/26 x2: The noise is gone! I can clearly hear and feel it for the first half mile after engine start, and then it goes completely silent. I will be getting my front differential replaced next week, and I believe that will fix it.
