feelthemusic8
I have a 2007 Limited Expedition 5.4 with 208,000 miles. It's having a problem with a rough idle in hot weather.
Typically, at night or when day-time temps are below 90, it runs fine and I have no idle issues, even after the truck is warmed up. But, if the outside temperature gets into the upper 90s, I'll have the rough idle when I'm stopped at a red light somewhat consistently. The problem gets worse the longer the engine is running and the longer I stay parked with the engine running.
Even in warm, but not hot, weather, if I let the truck sit and idle in park for 10-15 minutes, it seams to get "hot" and will start the rough idle. A couple of times it has even stalled out. If I press the gas and then let up, it will usually stop the problem except in the hottest weather.
I don't know if it is related or not, but I also have a very significant performance reduction (power) if the truck idles for long enough to heat up and especially if it is hot outside. The performance issue disappears after several minutes of running at highway speeds.
I also notice that the fan gets really loud, like an airplane, in the same hot conditions.
Finally, the rough idle reappears every time I pull into my garage at any temp. My driveway is very steep and I gas it up the hill but let off half way into the garage so I don't hit the wall. Right as it idles/coasts into place, it stutters.
I don't get any codes during any of these events. My temp gauge never moves past half way to hot. The oil pressure stays at approx 60% of the gauge.
Recent problems/repairs:
- 12 months ago had a heater hose burst which I replaced.
- 9 months ago fuel pump went out. At that time replaced:
- Fuel Pump
- Fuel Filter
- Spark Plugs
- COPs
- Dealing with this problem, I have done:
- Replaced Air Filter
- Seafoam crankcase and changed oil and filter twice last week.
- Cleaned MAF
- Cleaned Throttle Body
- Replaced Throttle Body Motor
- Have PCV Hose on Order, yet to install
I hate to just throw parts at it, but I'm at a loss now. Any ideas?
- Fuel Pump
- Fuel Filter
- Spark Plugs
- COPs
- Cleaned MAF
