1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Rough idle
Discussion in '2nd Gen - 2003 - 2006' started by Harry, Nov 21, 2020 at 1:47 PM.
  1. Harry
    Harry Active Member
    31
    39
    Mar 11, 2017
    Dallas tx
    this is for an expy 03 4.6
    so this week the truck started idle rough. like it was gonna stall. but it keeps running. i replaced the IAC last year when it had the same symptoms and it fixed it. but now its back again. any advice on where to look. thank you
  2. riphip
    riphip Full Access Members
    68
    286
    64
    Nov 6, 2018
    Memphis, TN.
    Look at VACUUM LINES FIRST. Easiest/cheapest thing to check and replace. Age,miles and heat deteriorate the rubber and causes leaks. PCV lines also (vacuum)
    MrSticker and Trainmaster like this.
  3. Harry
    Harry Active Member
    31
    39
    Mar 11, 2017
    Dallas tx
    where do i find the PCV LINE? i also disocvered a leaky radiator hose. which i will replace
  4. riphip
    68
    286
    64
    Nov 6, 2018
    Memphis, TN.
    Ck passenger side valve cover. Remove battery & check hose (vac) attached to vac reservoir, etc.
    I knew all of mine needed replacing so I pulled the plug and did them all. Rockauto.com
  5. Harry
    Harry Active Member
    31
    39
    Mar 11, 2017
    Dallas tx
    thank you!
  6. riphip
    68
    286
    64
    Nov 6, 2018
    Memphis, TN.
    You are more than welcome. Vacuum lines can be so problematic after mileage, years and heat under he hood, Found that out on my antique Ford diesel trucks. Check also for moisture/cooling fluids in spark plug areas. The repairs are just hard to get to areas at times. Love my 2004
  7. riphip
    68
    286
    64
    Nov 6, 2018
    Memphis, TN.
    PVC is the BLUE Thing in valve cover with hose mounted
    Harry likes this.
  8. Hamfisted
    Hamfisted Full Access Members
    1,019
    376
    Nov 20, 2012
    Ft Lauderdale
    riphip likes this.
  9. Harry
    Harry Active Member
    31
    39
    Mar 11, 2017
    Dallas tx
  10. Harry
    Harry Active Member
    31
    39
    Mar 11, 2017
    Dallas tx
    one more thing. where would i find the throttle positioning sensor?
Share This Page
