Running boards in the summer
RichCam
Charlotte
I have a 2020 limited and like most have had running board issues... The dealership replaced the module under warranty and about 6 months later (when warranty was expired) they started acting up again...
Dealership could find nothing wrong and recommended replacing them both... Not for that price..
I limped along through last summer, washing, lubing, etc... Still with intermittent success....
The in about Oct of last year they started working.... ALL THE TIME... it was amazing..
I almost forgot there was an issue until the first warm day in February and the old problem was back... So cooler weather work great... Warmer weather intermittent..
Anyone else experience this or have any ideas?
duneslider
Utah
I think it is just the nature of them. If I am good about cleaning, cleaning, cleaning, and lubing it really good they seem to work fine but they do require a fair amount of work to keep them happy. I def haven't 100% figured them out but I am pretty sure I don't clean them often enough and lube them often enough.
Hellwig
Electrical running board and sunroof are the two things I avoid on any vehicle I purchase
Fizzy
Alberta, Canada
I was having problems in the winter, with salt/sand in such prolific use here on the roads. I followed that YoutUbe video to the letter, and it's been 2 winters and 1 summer without so much as a whimper out of the running boards.
I also added mudflaps, primarily to prevent the buildups of giant snow-turds on the running boards that was weighing them down. But maybe that has helped reduce the amount of sand getting into the running board joints too.
DieselMonk
Atlantic Canada
I’ve had now these automatic running boards twice. I never done anything to them and always worked. Don’t have mud guards installed either. While most of my driving is on pavement, I do off the pavement here and there. No problems with winter snow on the running boards either.
texsn95
Houston
What video?
texsn95
Houston
Cool thanks, I like that dude's videos. I did use some silicon spray on the pivot points of ours not long after we got it, so maybe will make it a yearly maintenance thing. They seem to work OK so far as long as I don't mess with any of the delay timer settings.
DieselMonk
Atlantic Canada
I gave up on Fluid Film long time ago. I think this stuff is awful. One you use it after a while it dries a little and the gunk almost solidifies. Add cold to the mix and everything really starts to lock up or move hard. Put something else like grease or PTFE oil in there and keep that expensive crap out of there. I don’t even use Fluid Film as an undercoat anymore. There are better products that are cheaper.
