Rob Adams
Hi all,
I wanted to ask a couple of questions here to see if any of y'all could give me some guidance. month and a half ago AC compressor died in the 05...full failure...necropsy showed metal shavings/gunk in everything. Had to replace it to the tune of 2800 bucks. (new condenser/dryer, compressor, coils, etc) For years the AC suffered in slow/no speed situations so I thought maybe the plugged up/failing AC unit was to blame. Had even replaced the clutch with a ford factory viscous fan clutch but it didnt help. Fast forward to Southern oregon hot summers and the AC is suffering again even with a completely new system. Took it back and they told me that the fan clutch (which was barely a year old) was not kicking in soon enough even when the truck was sitting in the sun on a 100 deg day and the fan wasn't pulling enough air over the coils. They recommended that i put in a severe duty fan clutch (like cop SUV's use) or e-fan. I am still reeling from the ac replacement and can't afford the efan so I got a Hayden Severe Duty clutch and put it in...seems like it's definitely "engaged" more of the time now and pulls a lot more air thru...which makes the AC run better...but the truck is now quite a bit louder.
Do any of you all have experience with the Hayden Severe Duty? Does it seem like it's engaged more of the time? Should it be one of those things that I only put on in the summer and then swap out for the ford factory one in the winter? I don't think the ford one i bought was bad in just over a year, but it sure wasn't doing a great job in the super hot temps so I'm just not sure if it was working 100% right either. It passed the basic tests for a good clutch before I took it off....
Just don't know if leaving this severe duty one on all the time is going to really f my already bad gas mileage (mrs uses the expy for around town kid hauler).
