gflat65
2002 expedition 5.4L
There is a severe misfire and hesitation at all speeds. I can't get my scanner to allow communications (scanner works on all of my other cars).
I changed the fuel filter and did a sea foam treatment today. On the blow out drive, the battery light was on, went off, but then came back on during the drive
I had the battery checked. It's low (12.3V), but still had over 750 CCA. Could a weak alternator create issues with the scanner? What else can I check to determine why I can't communicate (I used to be able to on this vehicle). I notice that there appeared to be a leak at the negative post on the battery after the blow out drive.
No idiot lights staying lit, but Service Engine Soon will flash sometimes when its misfiring really badly (can't go a mile without a misfire, but the degree of misfire changes).
Plugs have ~8k miles in them (motorcraft). I've changed a few cop's over the last year, but didn't do them when I replaced plugs. Truck doesn't get driven much, obviously.
Replaced several sections of vacuum tubing today (lots of rot).
Any ideas on the OBDII communication problem?
Ideas on what else to check on the misfire/hesitation/power loss issue?
TIA
TIA
