Don’t wanna go too narrow though bc you’ll risk rolling the bead off during turns or when you have a heavy loadShould I order wider?
Will the this tire fit underneath in the spare spot?You and @CommO 33/12.50s should fit. You need 3” up front for 35s to fit on factory offsets and no trimming. I run 3/2 with 35/11.50/20 On factory +44 and they did not require any trimming but we’re super close to needing it. I put 1.25” boras on to push the tires back out of the wheel well and had to move my electric running boards and do some fender plastic trimming. Bilsteins and 33/12.50 on anything from +10 offset your should fit
Not the look I'm going for.Not necessary unless you want that weird look with the sidewalls of the tires sit behind the lip of the wheel
I e looked at putting one under there but never really committed to trying itWill the this tire fit underneath in the spare spot?
Looks good! How is it on the highway?
I'm thinking about running some bigger tire under mine ('11 XLT EL). I think a 33x12.50 would be about as big as I'd need/want. If it were your Expy, how would you accomplish the lift required?
I think my struts may be a little on the mushy side so that is a consideration too.
Would the 5100s be sufficient? I read all prior 56 pages and I know I could do the 33 inchers with a 3/2 setup and possibly wheel spacers (plan to use stockish 18" Ford wheels...just don't really like the stock Expy wheels), but if I need new struts....may as well go that way if the 5100s are still obtainable, no?
This is also a family hauler, boat dragger, and sometimes the groceries take a ride from town to farm in it too so it would be best if it could be an all around performer, rather than something that can only just cross ruts. It doesn't have the intention to do hardcore offroading, but something where I can go do some mild driving around my farm without fear of getting stuck in a 6" rut would be good.
I've read and read this thread, just want a confirmation of what would be a good setup before slapping my card number on a website
Thanks....and holy hell, lots of excellent trucks in this thread. Maybe soon mine will be worthy enough to hold down a spot here too.
