Spare tire lowering tool
Noblenobles
arlington Texas
Ok so this is extremely frustrating. I have not been able to find anywhere the tool to lower my spare tire. Everything I read is that theres a super long tool like standard trucks have that you stivk through the bumper. My 06 Expy has a water proof cap near the jack storage and a rectangle hole inside where you insert a tool to raise and lower it. Literally no where have I found the tool for it. Now Do I have something I can use well yes. Thats not the point I want the actual tool. Does ANYONE have a part number or link to where I can acquire this? Really was avoiding the dealership. Sorry for the rant but its wild to have the internet and not be able to find what should be a easily accessible tool.
Florisarn
I have a 2026. There are three long tools in the cloth case. It is the long skinny one that folds on a pivot. But it is both a hassle to get it out and the case is attached to the jack which scratches the interior easily. When I am at home I leave the tool case alone and use a 3/8 inch drive rachet. After putting on the extension, it fits right in the rectangular hole and makes quick and simple work of lowering and then raising the spare to check the air pressure. Before I started doing this, ninety percent of the time was unscrewing the knob to unlock the case, wrestling the case out of the tight fitting compartment, unwrapping the troublesome velcro, taking the tool out, using it and then wrestling it back into the tight compartment.
99WhiteC5Coupe
I bought a new 2015 Expedition Limited and quickly started carrying a standard 3/8 inch ratchet with an extension in the jack compartment - which worked much better than the tool provided by Ford.
I don’t have the Ford part number you requested.
ManUpOrShutUp
PA
Your profile says you're in Arlington TX area, so try one of these U Pull It yards. I took a quick look at the Ford Expediton inventory on the Pick N Pull and it looks like the Fort Worth location has a ton of Expeditions.
JerryT
FL
Ok so this is extremely frustrating. I have not been able to find anywhere the tool to lower my spare tire. Everything I read is that theres a super long tool like standard trucks have that you stivk through the bumper. My 06 Expy has a water proof cap near the jack storage and a rectangle hole inside where you insert a tool to raise and lower it. Literally no where have I found the tool for it. Now Do I have something I can use well yes. Thats not the point I want the actual tool. Does ANYONE have a part number or link to where I can acquire this? Really was avoiding the dealership. Sorry for the rant but its wild to have the internet and not be able to find what should be an easily accessible tool.
Did you check in your engine compartment above the radiator?
Taekwondad40
I modified my whole kit to work with my cordless ½" drive impact. It's soooooo much faster! Yes, that includes my (now super fast) scissor-jack! Added a cordless compressor for when a tire is low too. Extra batteries and a battery charger for the 12v power ports...
Grrumpy
Navy Law Enforcement
Careful,
It was made to be spun by hand,
you could tear it up very easily with a 1/2" impact.
Cordless impact are varible speed. I carry a Kobalt cordless 1/2 impact for use with our travel trailer lug nuts and sissors corner jacks and also lug nuts on truck when needed
I have been using a wratchet and 3/8 extension for the spare lowering but after reading his post tried the impact with a 3/8 reducer and extension. Low speed and it works perfectly. Drops the spare in a matter of seconds.
whtbronco
Winchester, VA
Careful,
I used to buy scissor jacks at the salvage yard to use as adjustable jack stands on our Monte Carlo's with my impact as well. They only last 1-2 years or so before the threads get galled up. A little lithium grease seems to help. They were just $3 each though so I didn't care.
Anyway, an impact or before that I used a just a 1/2" drill does significantly reduce the life of the jack, but it sure is easier and faster.
Staff online
Al_Harley
