SSV Console insert for shifter
sonixpix
KW Ontario
Thought i'd share. I've owned my 2013 SSV for about two years and final got around to inserting the centre console and then designing the insert for the shifter space. I taught myself 3D design but had a solid AutoCAD background to start. I dont own a 3D printer and used the local library's. I designed my own because i didnt like the ones I found online and found them expensive.
It's about 10cm deep and i printed removable dividers (red) to customize it how i want. The black is ABS while the red is PLA.
It was a bit of a learning curve and trial and error. I made test jigs to make sure the dimensions worked, before the final print. The library had trouble printing it so i did it in two sections and glued it together with abs slurry from acetone. If I took it to a pro print place it probably would have worked out ok.
Since the print i made Sane modufucatiobs such as a radius on the top to soften the edge, and minor changes to the design . Not sure why as ill probably never print it again,
Would like some feedback.
Thanks
leebuller
connecticut
That looks great. I’m in the process of adding power leather seats out of a limited and a console to my 2010 SSV. Would you be willing to share the 3d printer file for the shifter insert?
Thanks
Lee
JayB66
Aurora, CO
That looks great! My 09 has a transplant console, and the shifter is on the collum. My mechanic put the power shut off for my winch in the hole.
No members online now.
lelizondo
