jfhvmh
Massachusetts
I have a 2014 Expedition EL 4wd with 158,000 miles, I replaced basically the whole front end suspension parts, here is the list:
Front Wheel Bearing Hubs
KYB Strut Assemblies
Upper Control Arm, ball joint included
Upper Control Arm Bolts
Lower Control Arm, ball joint included
Lower Control Arm and
Cam Style Adjusting Bolts
Inner Tie Rods
Outer Tie Rod Ends
Sway Bar Bushings
Sway Bar Links
4WD Actuators
With all that work done I still have approximately 3/8" free play on the steering wheel. Could that play be from the rack & pinion? Or something else?
Has anyone ever ran into this problem?
Does anybody have any thoughts, ideas or answers?
Any help would be Greatly Appreciated.
Many Thanks in advance.
AWAR
oregon
I would check the joints where the steering column changes angle outside of the cab. The way things rust where they salt the roads I bet that is where your looseness is coming from.
jfhvmh
jfhvmh
Massachusetts
Thank You AWAR for responding. If I remember correctly that part is a universal type joint. Do you have any idea if that is a replaceable part? I will check that joint for wear and if I can find a replacement.
AWAR
oregon
Might be part of the lower steering shaft assembly. Look on ford parts online for parts breakdownsIMG_1824.png
Staff online
Lukin
