1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Strange grinding
Discussion in '2nd Gen - 2003 - 2006' started by treagan82, Apr 7, 2021.
  1. treagan82
    treagan82 Member
    20
    Oct 16, 2014
    TN
    So, my truck has started having a weird grinding issue coming from somewhere in the back half of the vehicle. It only happens when going up hill and having apply the go pedal to overcome my own momentum. I have yet to hear/feel this going on flat road or down hill, and it happens 98% of the time on the highway. It does not do this around town (50mph and under). I replaced a wheel bearing last year and it is not making the same noise it was when I figured that needed to be replaced. It is extremely hard to troubleshoot since I can only do reproduce the sound on certain stretches of road. Any ideas?
  2. Yupster Dog
    Yupster Dog Super Moderator Staff Member
    53
    557
    303
    Dec 7, 2018
    Check your parking brake pads by pulling the rotor off the rear.
  3. treagan82
    treagan82 Member
    20
    Oct 16, 2014
    TN
    Is this just something that will randomly start happening?
  4. Yupster Dog
    53
    557
    303
    Dec 7, 2018
    No. but it is a good place to start looking.
    Does your parking brakes work?
    Do you ever use them?
    When is the last time have you pull the rear rotors? (not changing just the pads but actually pulling the rotors)
    when mine got to be rusted mess (I never used them) the same thing happened all the little bits would get to the emergency brake shoe at higher speeds and during fast acceleration.
    Plus if that not it, gets you under the truck looking and you could spot the problem.
    Hell you could find a shrub or something simple.
  5. ManUpOrShutUp
    ManUpOrShutUp Full Access Members
    1,397
    634
    Mar 27, 2016
    Northeast
    +1 on checking the brakes. I had a front caliper that was intermittently sticking on me last year. I knew the wheel hub assembly on that same wheel was on its way out, so initially that's what I thought it was. When I took a closer look though, I saw the rotor was looking pretty ragged. And when I pulled the wheel, it was clear that the caliper had partially seized up on me.
    I had this happen a couple months ago. I was driving home and started hearing a little tap under the truck. Hmm, I had better check that when I get home. Then it starts getting louder and louder until it sounds like someone is beating the undercarriage with a club. Lo and behold, it was a fairly large branch that had somehow gotten wedged under the truck in a way that it was hinged on there at the upper end. Every time the lower end fell, the road would send it hurtling back into the undercarriage and it just ping ponged back and forth.
  6. JamaicaJoe
    JamaicaJoe Full Access Members
    66
    218
    93
    Dec 20, 2020
    Oviedo FL
    Rear, Drive shaft universal joint.
    Sent from my SM-T350 using Tapatalk
  7. treagan82
    treagan82 Member
    20
    Oct 16, 2014
    TN
    I will look into all of these this weekend!
Share This Page
