I have never seen an amp with only a 20 amp fuse, or even 30 amp. I would think you could get away with a 100 watt amp, but there is a catch. When you have bass hits, the capacitors in an amp aren't big enough/don't store enough power, so when you have bass and stuff the amp draw is more than 30 amps, even on a smaller amplifier. Plus take in account resistance when having a smaller gauge wire, so you draw more amperage. No good outcome... The best bet is to run a minimum of a 8 gauge, with a remote turn on lead, and a set of RCA cables.
