John Christopher
Leave it in drive and use the brakes. Problem solved Lol. I was told and confirmed it with Scotty Kilmer, that down shifting on large hills puts a strain on the drive train. Brakes are cheap, engines aren't.
i have strong doubt with that statement about strain....but who knows..Leave it in drive and use the brakes. Problem solved Lol. I was told and confirmed it with Scotty Kilmer, that down shifting on large hills puts a strain on the drive train. Brakes are cheap, engines aren't.
and ecm will not allow a shift to occur, no matter the selection if it exceeds rpm limits.Strain? Mmmyeah... if you suddenly slam into first gear for emergency redline engine braking, sure
Otherwise? It can deal, it's a truck not a millenial
When I do a descent on a steep mountain road my 2017 Expedition surges at about a 1 sec rate for most of the descent. This is a run from Alta Ski Resort to the Salt Lake Valley floor. I use third and second gear for most of the 7 mile descent and there is a distinct surging from the engine. I called the dealer about it last year and he said not to worry about it but I would like to know if anyone else experiences this and if it is thought to be a problem. I only have about 11,000 miles on the vehicle and it was doing it since I had less than 3000. It is a little intermittent and seems to be worse at some times than others but it definitely didn't happen with the Suburban I had before buying the Ford.
My 2017 Limited was doing this when in manual between 2nd an 3rd coming down Sugar Mountain (5500' peak) NC high country. At 13,000 miles as reported on this site the transmission failed and required valve body replacement after transmission acted like was popping out of gear. If transmission is not designed for hills why does the manual reference the use of M setting? Ford repaired free of charge but we were nearly stranded at night on bad road and limped home. In any event suggest you get friendly with your Ford dealer soon.....When I do a descent on a steep mountain road my 2017 Expedition surges at about a 1 sec rate for most of the descent. This is a run from Alta Ski Resort to the Salt Lake Valley floor. I use third and second gear for most of the 7 mile descent and there is a distinct surging from the engine. I called the dealer about it last year and he said not to worry about it but I would like to know if anyone else experiences this and if it is thought to be a problem. I only have about 11,000 miles on the vehicle and it was doing it since I had less than 3000. It is a little intermittent and seems to be worse at some times than others but it definitely didn't happen with the Suburban I had before buying the Ford.
