Navyfam00
Good day to all! I’ve got an interesting one that has me, as well as an auto electric shop absolutely perplexed. Here’s the deal: 2004 Ford Expedition Eddie Bauer 4x4 5.4, has the most strange
issue where the tail lamps and OR reverse lamps begin to glow on and off intermittently when the vehicle is off and parked in the garage. Yep, no rhyme or reason why one will glow when or vs the other, but that’s been going on for 7 months, and I haven’t been able to fix it. The auto electric shop in town swore that it was the fuse block down in the passenger side kick panel, which i’ve since replaced- but that’s doesn’t appear to have been the culprit, as the issue returned since the replacement (although, is was hopeful, as I hadn’t seen the issue for several weeks after the replacement— but the fault did in fact return). The lights will dim at random, sometimes brighter more on one side than the other, and it makes no sense to me at all. The car is a good car, but I can’t dump thousands into it, and it’s really beginning to make my wife and I feel like there’s no other option. A couple more possible hints — the aftermarket car stereo reverse camera kicks on intermittently while driving, presumably because is detecting a voltage in the camera trigger wire, which i neatly tied into the passenger side reverse lamp bulb assembly. This leads me to believe that even when the car is running, that there is/are stray voltages in the lighting circuits, which would
trigger the stereo head unit to believe the vehicle is in reverse.
Any help would be amazing— and i’d really really appreciate any advice. Thank you very much!!!
Respectfully,
Joe
Respectfully,
Joe
