lefty hack
my button was sticking about 3 months ago... tried air compressor and compressed air from a can ultimately replaced via warranty.... lift gate just stopped working last week warranty job replaced the lift gate motor.
My Dealer replaced the button AND the trim piece it snaps into last summer. Been ok since.Mine was replaced a couple months ago, and within about a week it got stuck again. Then, the next morning it was fine and hasn't happened since, I'm sure it will again though. I'm curious, someone on here mentioned they had the button trim piece replaced and that seemed to help. Anyone else try this?
Mine was sticking so I used some CRC electrical QD cleaner last week and it has been working well since. Thank you for the ideas in this thread.Have had same problem. Decided to try WD40 - sprayed it around the crack between button and the trim. After a thorough bath of WD40 to get the grit out, works again. Took only a couple minutes. Not sure if WD40 will damage the switch over time, but for now problem seems to be solved.
Just following up. Mine is still working fine.Mine was sticking so I used some CRC electrical QD cleaner last week and it has been working well since. Thank you for the ideas in this thread.
