Temp gauge dropping to zero, fault codes
Shantheman73
Kansas City
Hey all...
Driving on highway today...Had check engine light come followed by my temp warning light...then the gauge dropped to C, then back to normal, then back to C...
I checked SCTx4 and it had codes p0119 and p1289.
Both have to do with coolant system. I wonder if I have a bad temp sensor? The coolant doesn’t look too bad at all. Not sure if thermostat could play a part in this?
Shantheman73
Shantheman73
Kansas City
Finally got it out. And yes, that is anti-freeze not urine. Lol
Hopefully a new one will do the trick
Shantheman73
Shantheman73
Kansas City
Ok. I’m at a loss.
CHT sensor replaced. Thermostat replaced. New coolant.
I started it up and it’s still throwing the P1289 code after I cleared it twice.
I also noticed the temp gauge stays on ‘cold’ even when the engine is clearly warm and running for 10 min.
Would a bad gauge cause the PCM to think it’s overheating when it’s not?
Boostedbus
Maryland
Check the wires going to the temp sensor for open circuit. Possibly a critter of some kind did some chewing.
Yupster Dog
Super Moderator
Super Moderator
Defiantly check the harness, also you have to be very carful while installing the new sensor not to damage the plastic side. I have done that.
Shantheman73
Shantheman73
Kansas City
I’m thinking wiring has to be the issue. I was also wondering about critters.
I need to figure out where to check tho? Back of the engine?
I’m trying to avoid taking it to the dealer but dang it...getting to a wire behind the engine sounds more daunting than what I did today.
Shantheman73
Shantheman73
Kansas City
Update: Had to finally take it to the dealer. It ended up being the wire between the harness and CHT connector. I spent a small fortune having them replace a freaking wire.
Back up and running though...thankfully.
