Timberline Front Bumper Cover
RacerBX1
SE Michigan
In the beginning of August I hit a deer which took out my grill, bumper cover, and everything between the grill and the radiator fans, plus both headlights. Getting the vehicle back I didn’t recall how un-supported the bottom of the bumper cover is (the silver part). For the people with Timberlines does yours allow for the bottom of the silver part to be moved front to back several inches, say two to three inches each way? Also, how much movement can you get under the fog lights. Mines about an inch or two in each the front or back direction. I’m trying to figure out if the Collision missed something, forgot to attach something or that’s how it’s always been. I remember some movement, but don’t recall that much. But then again the memory is not what it used to be. Also took a month to get it back. Thanks for any help with these questions.
R
RacerBX1
SE Michigan
Answering my own question in case anyone else runs across this. The bottom of the silver part of the bumper cover is flexible but should only move an inch or so in each back and forth direction. When the collision shop put things together for me there was a lot of movement. They did many things poorly so I had them redo some of their work and in the process surprise, surprise the lower bumper cover flex’s a lot less then prior to the rework.
gunner1416
