GlennSullivan
My days of towing a car to the track loaded with tools, spares and buddies are long over. But that was accomplished with a Diesel Excursion.And the most important thing Ugh stated is "...go weigh your vehicle per axle". And I'll add that if you are exceeding your GAWR (most likely rear), regardless of what the tires will or will not support, you are off the reservation from a brake and handling standpoint. These are light vehicles made for light towing. There are a lot of trailers out there that might advertise that they are within the tow capacity of your Expedition; but, once you load your vehicle with gas, luggage, people, dogs, cats, surf boards, etc., then hook up your two axle travel trailer full of gear, batteries, propane, etc.....you will be surprised how far over your rear GAWR you are. Personally, I've been right on the line with Boy Scouts and gear and NOTHING on the receiver. I hate to be a buzz kill....but, if you're doing a lot of towing of things other than small boats, and utility trailers...you need to step up to a Super Duty.
These days my trailer is a 1500lb aluminum Featherlight, with only my wife and a few suitcases onboard and 1 of 3 cars on the trailer - 3100lbs, 3400lbs and 4700lbs respectively.
Ive CAT Scaled with each car and the package with the 4700lb car was right at the rear axle limit, even though the total trailer weight was only 6250lb. The nice thing about car trailers is you can adjust the position of the car to get the tongue and axle weights where you want to be.
I definitely feel the difference when I’m towing the 3100lb car vs the 4700lb one and wonder what it feels like towing a 7,000lb travel trailer with a 10’ high face.
