Just to make sure we're apples to apples, I didn't cut the shaft, just the threads on the very end of them that if I remember correctly, are used to install the brake disc nut.How did you go about cutting the axle shafts?
I put the rims on and that's when the center cap popped out. I first tried to use a dremel and remove some of the center cap from the inside to make it fit, but then I ended up marking the threads and cutting. When I cut them, I put a nut on the threads and then took a 4" grinding wheel to it, so that I wouldn't marr up the rest of the threads. Then when I was done cutting I took the nut off to make sure they were still good.
