Deadman
Exactly. There's many Platinum's running around without a locker, and tow pack.The Platinum only has the locker if you select the HD Tow Package with 3:73 rear end.
*Waves*Exactly. There's many Platinum's running around without a locker, and tow pack.
Exactly, the 2007-2014 Expeditions with the Control Trac 4WD system have 4 wheel traction control with an off-road mode according to the manual. This applies brake pressure to wheels that are slipping via brake application and sends power to a traction wheel. They did away with the LSD in 2007 because the two would fight and in testing they found the 4 wheel traction control to be more effective than a single lsd. The traction control on mine is a totally different animal if in 2WD or 4WD. According to the manual off road mode is automatically engaged in the 4L selection which alters the braking bias.With all the electronic crap on these newer vehicles, a locker can barely do its job, because the brakes often slam on before the locker can even lock up.
I would have thought a Locker locks it and runs that way … not kicks in when needed?With all the electronic crap on these newer vehicles, a locker can barely do its job, because the brakes often slam on before the locker can even lock up.
So, I think I'm starting to understand how my 2014EL works. If I have it in AWD power will be delivered to front and rear wheels. If rear starts to slip then the computer will send more power to front wheels to try to keep them turning at same rate. I have a LSD in the rear so if one rear wheel starts to slip the computer will apply brakes to that wheel and the LSD will give more power to the other rear wheel. If I didn't have LSD in rear and one wheel started to slip then it would spin and I'd lose all traction in the rear. If I had a locker in the rear both rear wheels would turn at same speed and if one started to slip the other one would keep driving. Do I have this right? Oh .. and LSD's kind of stop working after 100K miles or so.
