Towing Question
montecarlo31
I've got a nice reese set up if you want to buy it, I inherited it with a trailer. If you want it I'll let it go for 135 bucks. I can meet you or have one of my guys meet you in Houston. I can snap you some photos in the morning if you want, it comes with a friction sway control as well.
If you are looking in the higher dollar range Anderson is the only way to go.
Andersen 'No-Sway' Weight Distribution Hitch
Pappy
I bought an EAZ-Lift WDH with friction sway control when I replaced my rear tires. Made a difference like night and day. It looks exactly like that PPL unit and was probably made in the same building.
rollinstone
Seattle
I've been using the Andersen Anti-Sway WDH for 2 years, now. The whole system weighs only 60 lbs and it's very solid. Easy to remove/hookup at campsites...and it has a very wide weight limitations...up to 14,000 lbs trailer weight and 1,200 tongue weight. Many of the others have narrower weight carrying limitations so ya gotta get one that fits your specific weights. If you go over or under, your WDH is going to be less than effective.
Rcurtis
Indiana
4 pin to 7
Im wiring my 4 pole to a 7 pin. I've got everything hooked except the purple wire on the 7 pin. This is the wire that overrides the reverse lockout on the trailer. Direction say to hook the purple wire to the backup light, but it doesn't reach. There are wires down by the hitch but I don't know which of them to splice into?? Please help. Everything else is hooked up and they work.
savbraze
