Trailer Sway Control questions
JasonH
Houston, TX
Cool. Assuming you take them off when not towing, do they leave marks? Does your Expy have the "puddle light" knobby thing to clear also?
I never noticed any marks. The straps and buckles are rubber and plastic. Be sure to clean the mirror housing first. I didn't have any issues with fit but Amazon is pretty good about returns if you don't like them. The one issue I had is that the extra drag can result in the mirror folding if there are headwinds.
chuck s
I've been using this same set of McKesh mirrors since 2003 -- yep, the same set. Replaced the pads that touch the door maybe once. I set their width so I can see farther behind the trailer. They stay in the camper when it's in storage. I don't obsess over the finish on the truck -- it ain't going to Pebble Beach for the Concours d'Elegance.
-- Chuck
tominwi
tominwi
Up North
-- Chuck
Haha my other truck is Honda from 2005. Only has 115K miles and while it looks pretty good still, it's our "beater" vehicle and I hope to keep it forever.
Fasttimes
Miami
Best mirrors I've had. Using them now on my 17', used same pair on my 10'.
Aero Mirrors
Pawpaw
Raceland, La.
I had the strap on mirrors extensions from Camco. Tightened them up and one strap broke. Super cheap China made junk...I'd stay away from these. Seems like the max towing package should include max visibility mirrors!!
chuck s
The car next to my Expedition in the little photo on the left is a 2006 Honda. Only a year newer than yours. Like you l'll let my widow sell it. :) No towing.
-- Chuck
tominwi
tominwi
Up North
Yes, they already fold-in tight, why not add extend-out???
tominwi
tominwi
Up North
-- Chuck
I like to brag that we got the first 2006 Honda Ridgeline sold in Austin Texas back in March of 2005. Wife had wanted a Pilot but when we heard their new Truck was coming-out, we were ahem all-in! It continues to serve us well.
tominwi
tominwi
Up North
The following explanation of the Expedition's Trailer Sway Control is provided by grok.com:
The 2024 Ford Expedition's Trailer Sway Control (TSC) is an advanced safety feature designed to enhance stability when towing a trailer. It operates as an integrated part of the vehicle’s broader AdvanceTrac® with Roll Stability Control™ (RSC™) system, leveraging a combination of sensors, software algorithms, and precise control mechanisms to detect and mitigate trailer sway before it becomes a significant issue. Here’s a detailed breakdown of how it works:
### Core Mechanism
Trailer sway occurs when a trailer begins to oscillate side-to-side due to external factors like wind gusts, uneven road surfaces, passing vehicles, or improper loading. If unchecked, this can lead to loss of control, fishtailing, or even a rollover. The TSC system actively monitors and corrects this instability using the following technical components and processes:
1. **Yaw Rate Sensing**:
- The system relies on a yaw rate sensor, a key component of the AdvanceTrac® system, which measures the vehicle’s angular velocity around its vertical axis (i.e., how much it’s rotating side-to-side). When towing, this sensor can detect irregular yaw motion that deviates from the driver’s intended steering input, indicating potential trailer sway.
2. **Detection of Sway**:
- Sophisticated software algorithms analyze the yaw rate data in real time, comparing it to a baseline of normal vehicle behavior. The system distinguishes between intentional maneuvers (like turning a corner) and unintended oscillations caused by trailer sway. It does this by cross-referencing steering angle, vehicle speed, and lateral acceleration data from additional sensors.
3. **Corrective Actions**:
- Once sway is detected, TSC intervenes with two primary methods:
- **Asymmetric Braking**: The system applies selective braking to individual wheels—typically on the opposite side of the sway direction. For example, if the trailer sways to the right, brakes might be applied more forcefully to the left-side wheels. This creates a counteracting force that pulls the vehicle and trailer back into alignment.
- **Engine Torque Reduction**: Simultaneously, the system reduces engine torque by adjusting throttle input. Lowering the power transmitted to the wheels reduces the forces exacerbating the sway, giving the braking action more effectiveness.
4. **Feedback to Driver**:
- When TSC activates, the driver may notice a pulsing sensation in the brake pedal and see the stability control warning light flash on the dashboard. These cues indicate the system is working to stabilize the rig.
### Technical Integration
- **Sensor Suite**: Beyond the yaw rate sensor, TSC uses inputs from wheel speed sensors, a steering angle sensor, and a lateral accelerometer. These provide a comprehensive picture of the vehicle-trailer dynamics.
- **Electronic Stability Control (ESC)**: TSC is an extension of the Expedition’s ESC system, which already manages traction and stability. The ESC’s ability to modulate brakes and engine power is repurposed specifically for trailer sway mitigation.
- **Compatibility with Trailer Size**: The system is designed to work with trailers up to the Expedition’s maximum towing capacity (around 9,000–9,300 lbs when properly equipped with the Heavy-Duty Trailer Tow Package). It assumes proper trailer loading and hitch setup, as excessive tongue weight or poor weight distribution can overwhelm even advanced sway control.
### Operational Nuances
- **Proactive and Reactive**: TSC is both proactive (detecting early signs of sway) and reactive (correcting it once it begins). The system’s response time is near-instantaneous, thanks to high-speed processing in the vehicle’s electronic control unit (ECU).
- **Adjustability**: In some configurations, drivers can disable TSC manually via the vehicle’s stability control settings (as noted in Ford’s owner manuals), though this is generally not recommended unless specific towing conditions require it.
- **Synergy with Other Features**: On higher trims like the Platinum MAX, TSC integrates with features like the Trailer Reverse Guidance and Pro Trailer Backup Assist, enhancing overall towing confidence.
### Limitations and Considerations
- **Not a Cure-All**: While highly effective, TSC cannot fully compensate for severe mechanical issues (e.g., a blown trailer tire) or extreme conditions beyond the vehicle’s design limits. Proper trailer setup—balanced loading, correct tongue weight (typically 10-15% of trailer weight), and secure hitching—remains critical.
- **Driver Awareness**: The system reduces sway but doesn’t eliminate the need for cautious driving, especially at high speeds or in gusty winds.
### Real-World Performance
In the 2024 Ford Expedition, powered by a 3.5L EcoBoost® V6 engine and paired with a 10-speed SelectShift® automatic transmission, TSC complements the vehicle’s robust towing capability. The fully boxed frame and independent multilink rear suspension provide a stable platform, while TSC adds an intelligent layer of control. Owners towing trailers up to 9,000 lbs (e.g., small campers or boats) benefit from this system, which Ford has refined over years of implementation across its truck and SUV lineup.
In summary, the Trailer Sway Control on the 2024 Ford Expedition uses real-time sensor data, selective braking, and torque management to detect and correct trailer oscillations, ensuring safer towing. It’s a seamless, driver-transparent technology that enhances the Expedition’s reputation as a capable full-size SUV for family adventures and heavy-duty tasks alike.
ms136
North Carolina
As an RV dealership service manager, I recommend that anyone using a W/D hitch inspect what you expect. In other words, assume that it has "not" been set up correctly and go through the drill of checking all settings yourself. Tominwi you may experience excessive porpoising with the Blue Ox hitch while towing with the Expedition, if so, the Equalizer brand and some others can offer a better towing experience with that tow vehicle.
