I’m repairing the leaking compression fittings on my transmission cooler lines under the radiator. I’ve cut the outer shell and removed it and the hose from the hard line. I’ve bought new rubber hose.
My thinking is I don’t trust just clamps to hold the hose on without a barb at the end of the metal line. I’ve tried to get the hose to pass over the barb left behind by the compression outer metal shell, but no luck, the hose is just too tight. I’m sitting on my garage floor and need some quick advice.
Should I go get a flaring tool kit and try to make a hose barb on the end of this metal hard line? I know lots of YouTube videos of guys cutting off the compression fitting and just hose clamping the rubber on, but transmission cooler line is considered high pressure. I’m afraid it will blow the hose off the hard line with just clamps alone.
