Transmission fluid type?
Jackie_Moon
Noticed my transmission fluid needed replacing at 208k. Took it to local mechanic. They say they drained and filled ****** with MERCON LV.
It was my understanding that MERCON V should've been used?? Am I wrong on this, and is MERCON LV compatible with the 4r100 ****** ?
If MERCON V should've been used, what the **** should i do?
Hamfisted
Ft Lauderdale
They should not have used LV ( Low Viscosity ) Mercon in place of the spec'd Mercon V fluid. It will now require a complete flush with Mercon V to fix the issue. The two fluids are not compatible. Mercon LV was introduced to improve gas mileage, not increase transmission life. Call around your area and find a shop that can do an actual flush, and make sure they use Mercon V.
Machete
My Rig. 2000 EB 4x4 5.4L
Illinois
Today tranny flush, front diff oil, transfer case oil, coolant flush, and ps flush.
Oil change last week.
She’s good for another 50,000.
