Transmission Issues - Is this the CDF Drum?
Philly 'burbs
Been lurking for while, so I know that the transmissions are an issue here. Please don't need to tell me to search, I've done my searches and research - my symptoms don't 100% align with others so I wanted to create a fresh place to document my questions vs hijacking someone else's thread. Might be my first post here, but not new to forums and how they work. Thanks in advance for constructive feedback and advice.
I have a 2020 Limited 4x4 with the HD tow package, just under 80k miles at time of posting. I bought it about 10 months ago with just shy of 70k miles, and didn't notice any weird behavior at the time beyond issue (1) and (2) below. I just chalked those up to just being how it was, but now I'm less sure. I usually drive around in normal drive mode (2wd, not sport etc.). I've been having the following issues:
(1) Since I bought it, its been "slow" shifting from Drive to Reverse, as well as the opposite. As in, when I back out my driveway, stop, shift to Drive and hit the gas, it just kinda sits there. Almost like it forgot to change the gear. It doesn't do it ALL the time, but most of the time. It also doesn't free rev like its in Neutral, but seems to hold itself as thought it realized its completed the gear change. This is an issue as I live on a road that people routinely ignore the speed limit upon, so there are times I need to be on my way swiftly... I've had people all but drive up my rear end as in my previous vehicles I'd have been long gone before this one decides to give me Drive. I've been backing into the driveway when I can, just so I can leave under power without switching gears. A workaround (that i dislike doing, as I'm not unconvinced it won't do more harm than help) is to click Neutral as I've got enough momentum to get outta the drive, and hit Drive right as I stop. That seems to force the gear change faster.
(2) At certain times, and under certain loads / rates of acceleration, it "clunks" going into 4th gear. It often does the skip-shift thing of 1-3-5, and I don't feel those shifts. But when I'm in sport mode, or accelerating at a brisk pace where it does use 4th, it occasionally clunks. I don't notice a flare, it doesn't seem like it drops to Neutral, but I can tell you it went into 4th by the feel.
(3) I recently completed a 1,500+ road trip with the family into the Smokies of TN (rental house was WAY in the hills, like 14% grade switchback kinda hills). It seems the trans loved to select 3rd gear and slip the hell outta the clutch (or whatever this automatic uses in place of a clutch) vs downshifting and locking up. Is that normal? This is my first Ford product, and first car in a while that wasn't a manual transmission that I could force into whatever gear I wanted.
(4) As I was withing a hundred or so miles of home returning from the trip, I became aware I can feel it shifting into 8th gear as well. This one IS a flare shift. It jumps up in RPM by 3-500, then clunks down into gear. Normally under light acceleration, but has done it it every single time since I first noticed the issue. This one is the most concerning to me, honestly - its the only one I can't modify my habits to avoid... and based on my knowledge of auto transmissions, is also a potential symptom of impending failure.
It seems like SOME of those align with the common CDF drum issues. Some of them align with common automatic transmission issues. Some of them are just weird quirky issues I originally chalked up to how this transmission operates. However, examining the constellation of all the symptoms, I'm somewhat concerned. I do NOT have an extended warranty at the moment, but I'm considering obtaining one as I have a feeling my trans is going to leave the chat sooner rather than later. Anything I can do to remedy this myself? I've heard that resetting the trans adaptative learning tables can help, as well as turning off the ability to learn via Forscan. But will doing those cause issues IF I end up getting the extended warranty? I'm mechanically inclined (engineer by trade) and love turning my own wrenches on my previous vehicles, so I'm not afraid of getting dirty and getting my hands in there. Just looking for some advice on how best to proceed / prepare.
Oh look, I wrote a novel. Thanks for attending my TED talk and all that. If you made it this far, I appreciate your dedication and hope you can offer some good advice. Thanks in advance yall.
Fizzy
Alberta, Canada
Go see my recent post in the Gen 4 forum. Had the same symptoms. Just got it back from Ford after the rebuild.
Yes, it's your CDF drum, but as you'll see in my post, over time it causes damage to much more in the transmission. Everything is consistent. Clunk/hesitant shifting 3-4-5, and 7-8. Lurching from P to R. If you leave it, you'll eventually start getting neutral-outs at highway speeds.
Yes, it will need a rebuild. Do you have any original powertrain warranty, or an ESP?
F
Philly 'burbs
Fantastic. I just checked your post, I'll follow along for updates as it ages in. I've heard too that lots of people are experience poor experiences after rebuild AND replacements... Perhaps I look into trading up into a slightly newer model that should have the new CDF parts baked in already... It appears I should have bought the Denali XL, lol.
I believe I'm beyond the factory warranty at this point, and I bought it used so I don't have an ESP. I wonder how hard it would be get an ESP on it now, then use it to fix the trans...
Fizzy
Alberta, Canada
GM has a recall right now for total engine failure, including the Yukon. So does Toyota. Both end up needing whole new engines.
Also, the 10 speed transmission was a joint venture between Ford and GM. The Yukon has the same hard parts as the Ford, but the unit is called the 10L80. There seems to be emerging problems with that too from what I've been reading.
You basically can't escape it - the issue is new vehicles - they are trying to 1) cut costs 2) increase performance 3) meet ever stricter emissions standards 4) meet stricter fuel economy standards. All this means vehicles that are not reliable.
We have a 1500km road trip this weekend - so that should be a nice consistent break in for it.
F
Philly 'burbs
If I didn't use this as a primary vehicle to huck my family around, I'd sell it and get an old diesel Excursion. Or something older that isn't designed to fail as quickly. But my family likes nice things and an old Excursion is not that, hahahahaha.
At least GM is paying for the engines, I'd assume at least being that its a recall. Having to shell out of my own pocket or play games with an ESP to avoid paying 4-6k out my own pocket for a rebuild or a new transmission is silly on a five year old $70k vehicle. If Ford wanted to admit they have a shit design issue and COVER the replacement costs, I'd be fine with it.
Scooter455
Missouri
Well GM has to pay for the engines - its happening under the factory warranty some customers only have a couple thousand miles on their vehicles. I'm also hearing it could be months before GM actually has the parts for to the engine swap. So they are without a vehicle that they are making payments on. Just happened to a friends Escalade. HE traded it for a Lexus. Wit this recall out there theses vehicles have lost their value. You should be glad you didnt get that Yukon
F
Philly 'burbs
Or, it might be a good time to scoop up a Yukon on the cheap? Looks, one man's value loss could be another's entry point, haha!
Tried to look into adding a Ford ESP, which COULD be done on a used vehicle - if I didn't have the magic combination that made it too expensive to cover per the Ford ESP guys on the phone. I'm wondering if they price in the potential for transmission failure when they quote the policy... Anyone have experience with a third party ESP? I really don't want to end up paying out of pocket for a new / rebuilt transmission. If it was any other part of the truck, I'd replace the parts myself. But there is far too much witchcraft that happens inside an automatic transmission and that put it firmly beyond my comfort zone right now.
19ExpMaxPlatYYC
Calgary
I'm on my second transmission rebuild for a '19, the first under warranty the second because I reported fourth gear shift issues just before the ESP expiry. While a bit greasy, I'd see if they'll issue and ESP on the vehicle...and give it a bit of time before reporting...
I'd say these issues are pretty typical from my own experience. I did have a horrendously hard shift, dropped to neutral for my first rebuild.
MEXpedition
