5280tunage
Quick update, so far so good on how things feel and the tranny has been staying a very constant temp which is good to see. But man I was annoyed, the night I brought it home, I noticed a bad and pretty loud rattle, anytime the vehicle was idling in gear, but not moving, i.e. sitting in the driveway. So today, put it up on ramps (which stands to be safe), and pulled the entire RCI skids off. I was going to do this no matter what to clean everything, given that everything was covered in tranny fluid from when it essentially blew. Man was it everywhere. But once I pulled them off, I pretty quickly found the issue. Looks like the dang tech lost two of the nuts that go on the heat shield studs on the tranny pan. Not only do the nuts look missing, but it looks like he or maybe the first tranny tech mangled the heat shield holes pretty bad.
Luckily I had some black oxide nuts that fit perfectly, and I used some small washers to help ensure the heat shield stayed in place. It was literally hanging down on top of the crossing Y pipe. I'm assuming they had to remove the Y pipes to do the tranny work, and it also looks like when they put them back together it was slightly lower which means it was coming in contact with my skid plate a little. Rotated and fixed that as well.
Super annoying, I'm actually annoyed that they didn't even try to clean the skid plates either, from all the oil. they've had it for almost 10 weeks combined. Why can't these guys have a little more pride in their work, the heat shield is the easiest part. I also noticed the external transmission cooler is slightly larger than the old one, maybe it will work a little better.
