Do you know the part number for that? Can’t seem to find it.Hi I had the same problem on my 2007, ended up being the valve body bridge seal blew out, had the same issues until it completly blew out.
Thanks for the pics, was able to read the part number on the bridge seal (7F401) and for my specific transmission the part number is 6L2Z-7F401-A.View attachment 31270 View attachment 31271 View attachment 31272 I don’t have them on hand, the parts guy at the dealer was able to look them up, I changed out the 4 tootsie roll looking seals too, they had to order them because they were different lengths.
Be careful what you touch on the valve body when you drop it down, they are sensitive to static electricity, especially the harness pins. Wasn’t a very hard job, just take out the bolts that hold the valve body up, not all of them
The original issue I posted about (jerking when coming to a stop) was solved, that was only from initially dropping the pan and replacing with new fluid and filter. After doing that, the jerking stopped.How did you make out?
