OGFlo54
03 Expedition XLT 4wd Triton 5.4
4R70W with a BW4416 TC.
So here’s the issue…
My speedo upon acceleration in 2H, AWD4 and 4H, maxes out at 100mph- I’ve clocked the actual speed around 25mph. When reaching 100 power is reduced and a clunking noise can be heard from the transfer case. It sounds as if the TC is engaging and disengaging and with each clunk the truck lurches or lunges. (If going up a hill the TC will actually engage for a moment or two depending on how long the hill is)
In 4L the speedo stops at 60mph with an approximate speed around 35mph no clunking or lurching. The truck will not shift into 3rd gear regardless of selector position. I’ve checked and verified that 4wd is engaging in all TOD settings and disengaging as well. I’ve also verified that the TCM is working using a multi meter and by the audible clicks moving from 4L to 4H.
I’ve replaced the VSS but as of yet have not replaced the wheel speed sensors. I’ve never had a check engine light or a blinking O/D light ,ABS light or a blinking or solid 4H/4L light. I’ve reset the PCM. I’ve checked the 4wd solenoid and check valves and it’s working properly. Vacuum appears ok as I’ve not heard any vacuum leaks and the fact that 4wd is engaging and disengaging. I drained the TC to check for a possible stretched chain thru drain plug but it appears to be fairly tight.
I do need to do a trans flush. All fuses are good and relays as well. There’s no grinding noise from either the transmission or TC. The TC shift motor is working but it’s old and I could probably use a new one. I’ve never had a 4wd till now so I wanted to do my research before bringing the issue to the forum.
Is there anything I’ve missed or not listed? Any advice or solutions will be welcomed and appreciated. Thanks for reading!!
