dbovine
Got a weird one today. Truck will not start. When you turn the key to the on position you get a buzzing sound from the dash on the passenger site and when you crank the key nothing happens, just continues to buzz. So I tried boosting it, the buzzing goes away when the booster cables are connected. but the truck still wont start. The battery appears to have lots of juice. We lifted the truck up and with the key in the on position and using a screwdriver we are able to get the starter to turn over but the motor won't fire. Took all the fuses out of the factory remote starter, still wont start.The starter sounds fine. Checked the fuse in the kick panel, fuse looks good. The truck started fine this morning, drove to a friends 20 minutes away tried to start it a couple hours later and above is what happened. Any ideas??
