Trying to avoid spending $ on new AC compressor b4 winter
micahbyrnes00
traverse city, michigan
I have a 2010 Ford Expedition Eddie Bauer 5.4L. My A/C clutch recently came apart and the outer clutch disc/hub came completely off the compressor.
From what I can tell, the actual A/C pulley and bearing are still intact and the serpentine belt is still running normally over the pulley. I ran the engine with the clutch hub missing and watched the pulley. It spins completely smooth with no wobble, grinding, squealing, or anything else abnormal. I also tried checking it for play/prying on it lightly with a screwdriver and it seems solid with no noticeable movement.
The piece that failed appears to be the clutch disc/hub that normally gets pulled against the spinning pulley when the A/C clutch engages. The splined center of that hub engages the compressor shaft, so with that piece gone the pulley is just free spinning and isn’t actually turning the compressor anymore.
The truck currently drives completely normal. The serpentine belt is tracking correctly, the A/C pulley is spinning freely, and there are no noises or wobble that I can see.
I’m in Michigan and we’re going into winter, so I really don’t need A/C for the next few months. I’m trying to avoid spending the money on a compressor or clutch right now if I don’t have to.
My main question is: Is it safe to continue driving it like this for the winter as long as the A/C pulley/bearing continues spinning smoothly and the belt stays properly aligned?
I know the Expedition can request the A/C compressor automatically when using defrost, so I’m also wondering if I should unplug the electrical connector for the A/C clutch until I repair it, even though the clutch hub itself is physically missing and therefore can’t engage the compressor anyway.
I’m mainly concerned about whether leaving the compressor like this could eventually cause the pulley/bearing to fail, throw the serpentine belt, or damage anything else.
I plan on repairing the A/C before I need it again. I’m just trying to figure out whether I can safely drive it through the winter as-is instead of replacing everything immediately.
5.4L V8
max78
AZ
You are fine, there is a snap ring (you can see it in the picture) holding the hub on. Mine fell off and I drove that way for 2 week while waiting for a replacement. Put some Loctite on the bolt when you go to reassemble it, I did after it fell off for a second time. . .
bryandreilly
