HazBeen
***This is a partial description of TSB 25-2023 -- Please see attached PDF document for full information***
This Technical Service Bulletin supersedes previously unposted multiple model-line TSB 24-2101, which is also attached below for comparison.
This bulletin supersedes 24-2101. Reason for update: update the vehicles affected, Service Procedure, and parts list
Model:
Markets: North American markets only
Summary
Issue: Some of the vehicles listed in the Model statement above may exhibit at least one of the following conditions:
This may be due to axial movement of the CDF clutch cylinder (7H351) sleeve causing hydraulic circuit leaks.
NOTE: If internal transmission service is required to address a concern detected with the CDF clutch cylinder following this article, technicians should carefully inspect and replace other transmission components and flush transmission fluid cooler only as necessary to confirm proper function. Add a new line to the repair order to document any additional repairs needed. M-time can be claimed on the additional repair line to cover labor. Refer to Warranty and Policy Manual for additional information. A thorough understanding of transmission description and operation will assist the technician with proper diagnosis, inspection, and successful repair of the customer concern.
NOTE: The Pressure Vacuum Transducer Kit (Rotunda 164-R9833) and VCMM Transmission Extension Kit (Rotunda 164-R9534) recommended to perform this article are no longer included with the VCMM Advanced Kit (Rotunda 164-R9823), and were discontinued in July 2023. Ford has confirmed a high percentage (80%) of Dealers have this equipment available to perform this article. Refer to Table 1 in the Service Procedure for equipment alternatives. In addition, VCMM Universal Probe Tip Adapter (Rotunda 164-R9834, or equivalent) is needed to perform this article. The Probe Tip Adapters are included in VCMM Advanced Kit (Rotunda 164-R9823).
Action: For vehicles that meet all of the criteria in the Issue and Model statements, follow the Service Procedure to verify hydraulic circuit leakage and replace the CDF clutch cylinder (7H351) if necessary.
Model:
| Ford 2018-2021 Expedition | Transmission/Transaxle: 10R80 |
| Lincoln 2018-2021 Navigator | Transmission/Transaxle: 10R80 |
Summary
• Harsh engagement
• Delayed engagement
• Harsh shift
• Delayed shift
• Illuminated MIL with DTCs P0751, P0752, P0756, P0757, P0761, P0762, P0766, P0767, P0771, P0772, P2700, P2701, P2702, P2703, P2704, P2705, P2707, P2708, P0729, P0731, P0732, P0733, P0734, P0735, P0736, P076F, P07D9, P07F6 and/or P07F7 stored in the PCM or TCM
