TSB 25-2131 - 2022 Exp/Nav + Other Models - 10R80 Trans - Harsh/Delayed Engagement And/Or Harsh/Delayed Shift - Built On Or Before 07/15/2022
HazBeen
Great Lakes
***This is a partial description of TSB 25-2131 -- Please see attached PDF file for full information***
TSB 25-2131 - 2022 Expedition/Navigator + Other Models/Model Years - 10R80 Transmission - Harsh/Delayed Engagement And/Or Harsh/Delayed Shift - Built On Or Before 07/15/2022
This bulletin supersedes 24-2436. Reason for update: update the Part List and Service Procedure
Model:
Ford
2022 Expedition
Built on or before 15-Aug-2022
Transmission: 10R80
2020-2022 ExplorerBuilt on or before 15-Aug-2022
Transmission: 10R80 (does not apply to 10R80 MHT)
2021-2022 F-150Built on or before 15-Aug-2022
2021-2022 MustangBuilt on or before 15-Aug-2022
Transmission: 10R80
2020-2023 TransitBuilt on or before 15-Aug-2022
Transmission: 10R80
Lincoln
2022 Navigator
Transmission: 10R80
Markets: North American markets only
Issue: Some of the vehicles listed in the Model statement above may exhibit at least one of the following conditions:
• Harsh engagement
• Delayed engagement
• Harsh shift
• Delayed shift
• Illuminated MIL with DTC P0751, P0752, P0756, P0757, P0761, P0762, P0766, P0767, P0771, P0772, P2700, P2701, P2702, P2703, P2704, P2705, P2707, P2708, P0729, P0731, P0732, P0733, P0734, P0735, P0736, P076F, P07D9, P07F6 and/or P07F7 stored in the PCM or TCM.
This may be due to axial movement of the CDF clutch cylinder sleeve causing hydraulic circuit leaks.
NOTE: If internal transmission service is required to address a concern detected with the CDF clutch cylinder following this article, technicians should carefully inspect and replace other transmission components and flush transmission fluid cooler only as necessary to confirm proper function. Add a new line to the repair order to document any additional repairs needed. M-time can be claimed on the additional repair line to cover labor. Refer to Warranty and Policy Manual for additional information. A thorough understanding of transmission description and operation will assist the technician with proper diagnosis, inspection, and successful repair of the customer concern.
NOTE: The Pressure Vacuum Transducer (PVT) Kit (Rotunda 164-R9833) and VCMM Transmission Extension Kit (Rotunda 164-R9534) recommended to perform this article are no longer included with the VCMM Advanced Kit (Rotunda 164-R9823) since July 2023. Supply of the PVT Kit (Rotunda 164-R9833) and VCMM Transmission Extension Kit (Rotunda 164-R9534) have been sold out. Ford has confirmed a high percentage (80%) of Dealers have this equipment available. Alternatively, Ford has tested suitable transmission fluid pressure gauges and developed procedures which reliably enable the capability to perform this article. Refer to Table 1 in the Service Procedure. In addition, VCMM Universal Probe Tip Adapter (Rotunda 164-R9834, or equivalent) is needed to perform this article. The Probe Tip Adapters are included in VCMM Advanced Kit (Rotunda 164-R9823).
Action: For vehicles that meet all of the criteria in the Issue and Model statements, follow the Service Procedure to verify hydraulic circuit leakage and, if instructed, replace the CDF clutch cylinder and the clutch and planetary container cylinder.
(Part List and Service Procedure are omitted from this post)
Warranty Status: Eligible under provisions of New Vehicle Limited Warranty (NVLW)/Service Part Warranty (SPW)/Service Part New Vehicle (SPNV)/Extended Service Plan (ESP) coverage. Limits/policies/prior approvals are not altered by a TSB. NVLW/SPW/SPNV/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool.
Labor Times
DescriptionOperation No.Time
2021-2022 Mustang 2.3L/5.0L Coupe/Convertible: Run CDF Test (Pass) (Do Not Use With Any Other Labor Operations)
252131A​
0.7 Hrs.​
2021-2022 Mustang 5.0L Coupe: Run CDF Test (Fail) Replace CDF Cylinder (Do Not Use With Any Other Labor Operations)
252131B​
11.3 Hrs.​
2021-2022 Mustang 5.0L Convertible: Run CDF test (Fail) Replace CDF Cylinder (Do Not Use With Any Other Labor Operations)
252131C​
12.0 Hrs.​
2021-2022 Mustang 2.3L Coupe: Run CDF test (Fail) Replace CDF Cylinder (Do Not Use With Any Other Labor Operations)
252131D​
10.4 Hrs.​
2021-2022 Mustang 2.3L Convertible: Run CDF test (Fail) Replace CDF Cylinder (Do Not Use With Any Other Labor Operations)
252131E​
11.0 Hrs.​
2020-2022 Explorer 3.3L/3.0L: Run CDF Test (Pass) (Do Not Use With Any Other Labor Operations)
252131F​
0.8 Hrs.​
2020-2022 Explorer 4WD 3.3L TiVCT: Run CDF Test (Fail) Replace CDF Cylinder (Do Not Use With Any Other Labor Operations)
252131G​
12.4 Hrs.​
2020-2022 Explorer 4WD 3.0L EcoBoost: Run CDF Test (Fail) Replace CDF Cylinder (Do Not Use With Any Other Labor Operations)
252131H​
11.3 Hrs.​
2020-2023 Transit 3.5L TiVCT/3.5L EcoBoost: Run CDF Test (Pass) (Do Not Use With Any Other Labor Operations Outside Of This Article) (Can Be Claimed With Operation P)
252131J​
0.7 Hrs.​
2020-2023 Transit RWD 3.5L TiVCT: Run CDF Test (Fail) Replace CDF Cylinder (Do Not Use With Any Other Labor Operations Outside Of This Article) (Can Be Claimed With Operation(s) P, Q Or R)
252131K​
11.4 Hrs.​
2020-2023 Transit RWD 3.5L EcoBoost: Run CDF Test (Fail) Replace CDF Cylinder (Do Not Use With Any Other Labor Operations Outside Of This Article) (Can Be Claimed With Operation(s) P, Q Or R)
252131L​
11.4 Hrs.​
2020-2023 Transit AWD 3.5L TiVCT: Run CDF Test (Fail) Replace CDF Cylinder (Do Not Use With Any Other Labor Operations Outside Of This Article) (Can Be Claimed With Operation(s) P, Q Or R)
252131M​
14.2 Hrs.​
2020-2023 Transit AWD 3.5L EcoBoost: Run CDF Test (Fail) Replace CDF Cylinder (Do Not Use With Any Other Labor Operations Outside Of This Article) (Can Be Claimed With Operation(s) P, Q Or R)
252131N​
14.2 Hrs.​
2020-2023 Transit AWD/RWD: Additional Time To Remove And Install Running Boards If Equipped (Can Be Claimed With Operations J-N)
252131P​
0.3 Hrs.​
2020-2023 Transit AWD/RWD: Additional Time To Check And Correct Front Toe (Can Be Claimed With Operations K-N)
252131Q​
1.0 Hrs.​
2020-2023 Transit AWD/RWD With Lane Departure Warning: Additional Time To Check And Correct Front Toe Includes Extra Time To Align LDW Camera System (Can Be Claimed With Operations K-N)
252131R​
1.4 Hrs.​
2022 Expedition/Navigator 4X2/4X4: Run CDF Test (Pass) (Do Not Use With Any Other Labor Operations)
252131S​
0.8 Hrs.​
2022 Navigator 4X2: Run CDF Test (Fail) Replace CDF Cylinder (Do Not Use With Any Other Labor Operations)
252131T​
11.7 Hrs.​
2022 Navigator 4X4: Run CDF Test (Fail) Replace CDF Cylinder (Do Not Use With Any Other Labor Operations)
252131U​
12.7 Hrs.​
2022 Expedition 4X2: Run CDF Test (Fail) Replace CDF Cylinder (Do Not Use With Any Other Labor Operations)
252131V​
11.4 Hrs.​
2022 Expedition 4X4: Run CDF Test (Fail) Replace CDF Cylinder (Do Not Use With Any Other Labor Operations)
252131W​
12.4 Hrs.​
2021-2022 F-150 4X2/4X4: Run CDF Test (Pass) (Do Not Use With Any Other Labor Operations)
252131X​
0.8 Hrs.​
2021-2022 F-150 4X2 2.7L EcoBoost: Run CDF Test (Fail) Replace CDF Cylinder (Do Not Use With Any Other Labor Operations)
252131Y​
12.3 Hrs.​
2021-2022 F-150 4X4 2.7L EcoBoost: Run CDF Test (Fail) Replace CDF Cylinder (Do Not Use With Any Other Labor Operations)
252131Z​
13.1 Hrs.​
2021-2022 F-150 4X2 3.5L EcoBoost: Run CDF Test (Fail) Replace CDF Cylinder (Do Not Use With Any Other Labor Operations)
252131AA​
11.7 Hrs.​
2021-2022 F-150 4X4 3.5L EcoBoost: Run CDF Test (Fail) Replace CDF Cylinder (Do Not Use With Any Other Labor Operations)
252131BB​
13.0 Hrs.​
2021-2022 F-150 4X4 5.0L TiVCT: Run CDF Test (Fail) Replace CDF Cylinder (Do Not Use With Any Other Labor Operations)
252131CC​
12.9 Hrs.​
2021-2022 F-150 4X2 5.0L TiVCT: Run CDF Test (Fail) Replace CDF Cylinder (Do Not Use With Any Other Labor Operations)
252131DD​
11.6 Hrs.​
2021-2022 F-150 4X4 3.3L TiVCT: Run CDF Test (Fail) Replace CDF Cylinder (Do Not Use With Any Other Labor Operations)
252131EE​
12.0 Hrs.​
2021-2022 F-150 4X2 3.3L TiVCT: Run CDF Test (Fail) Replace CDF Cylinder (Do Not Use With Any Other Labor Operations)
252131FF​
11.0 Hrs.​
Repair/Claim Coding
Causal Part:7H351
Condition Code:42
  • TSB 25-2131 - 2022 Expedition-Navigator + Other Models-Model Years - Harsh-Delayed Engagement ...pdf
67fe390
