Tyre size for 20
inzaghi316
UAE
I have a 2012 Expy El ltd.
It has 20" stock rim.
Current tyre 265 55 20.
Could i change it to 275 65 20 without any other modifications. If not then 275 60 20 will be good as i need some height.
Thanks
Adieu
SoCal
265/55r20 = 31.48"
275/65r20 = 34.07" ... would almost certainly need a 4 corner lift kit
275/60r20 = 32.99"... 33's fit stock I think? +0.75" of wheel in all directions (or more like +1" if your tires are worn out), +0.75 - 1" height
PS if your shocks and springs are good. If they're shot, you're screwed.
inzaghi316
inzaghi316
UAE
265/55r20 = 31.48"
So 275 60 20 fits without any issues?
Adieu
SoCal
Eh.... very highly likely?
IDK ask around, I've always been slightly lifted
Or just look yourself, if your tires are older measure +1" in every direction up down left and right, then repeat at wheels turned to the right and left... and see if any potential rubbing problems are present
275 treadwidth should be a non-issue since people run much wider, so probably safe to disregard that part
inzaghi316
inzaghi316
UAE
Will do. Maybe i think 275 60 20 will fit without issues. Will chk on other forums too.
Gary Waugh
Princeton, TX
Dont forget you will need to recalibrate your speedo or it is going to be giving the wrong speed reading and our boys in blue can make that an expensive issue very quickly!!
Gary
Adieu
SoCal
Gary
Nah
31.5 >> 33 is +4.8%
+2 mph @ 40, +3 mph @ 60, + 4 mph @ 90
Just go 2-3 mi "slower", keep the needle below 80 (and never pass 85) and you're good.
Plus your odometer will read a hair lower lol
