I promise I have read the manual and will quote it where possible
I have some questions about climate control the manual doesn't seem to answer
The front windshield heater elements for the wipers, how do you turn them on? Is it with the rear heater element or is it automatic? the user manual says "Windshield Wiper De-icer -- The windshield wiper de-icer turns on in low temperatures. "
Setting the mid cabin roof vents to blow warm air by using the front controls? Using the rear controls you can set the vent to blow from the roof vents, but I can't figure out how to do this from the front controls, I can set auto, fan speed, warm/cold but not which vents it uses. In sub artic weather having the roof vents blowing at the middle and rear windows helps prevent ice buildup on the inside (Welcome to Canada folks, I never knew this could happen in a car with the interior warm, but it does and it's a bugger to defrost, weird to watch your kids using an ice scraper on the inside of the car )
Auto start, sometimes if it is cold enough auto starting the car engages the heated steering wheel and heated seats is this user selectable somewhere? If it's -30C I don't mind this but at +4C the heated seats and wheel are a bit much
Apologies if these are obvious
John
John
