1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Usual suspects confirmation - slight engine shake at idle
Discussion in '2nd Gen - 2003 - 2006' started by getdealtwith, Mar 11, 2020.
  1. RichardH
    RichardH Full Access Members
    170
    34
    Nov 20, 2015
    Galveston, TX
  2. getdealtwith
    getdealtwith Active Member
    50
    33
    Jan 29, 2020
    US
    OK, so I thought I'd circle back here to report that I found that the vent line from the driver side valve cover wasn't plugged into the elbow piece right at the valve cover. The random shaking is 80% better now but not completely gone yet. I'll replace the pretty rotted hose along the firewall next and will check the motor mounts as well. Thanks for the support everyone!
  3. TobyU
    TobyU Full Access Members
    2,468
    825
    Apr 5, 2013
    Ohio
    So that was a pretty big vacuum leak. A good way to hear those is to take a 4 ft piece of rubber hose like 5/16 or 3/8 and put one end in the edge of your ear and run the other end around everything the engine you will hear the leak.
    Also the fuel trims on a scantool should have been high since vacuum leak.
    getdealtwith likes this.
  4. getdealtwith
    50
    33
    Jan 29, 2020
    US
    Excellent idea. I'll have to try that next time.
Share This Page
