I'm travelling a lot this winter, month at a time. Don't want my 2003XLT battery to run down and freeze. Battery Tender at AutoZone is $44, fughetaboutthat. Is it OK to just disconnect the battery? If I do that ... is it preferable to remove positive, negative, or both battery cables? Negative (ground looks a lot easier to remove). I've got a 3/6 amp battery charger but thats to not be used as a battery tender, right?
The Owners Manual says ... if battery is disconnected ... the transmission must relearn its shift settings, idle has to relearn, fuel trim has to relearn, and worst of all I will lose my preset radio stations. Sounds bad since everything works so well at the moment. Not sure I want to risk that.
