Variable Cam Timing and sludge
JasonH
Houston, TX
This is why you need a catch can
Call around for competing quotes. The issue is that a junkyard engine may not have had proper maintenance as well. Perhaps you can get a low mileage engine from a wreck swapped in.
Rebuild from an independent shop? Maybe sell it as needing repair and get a new one.
Out of curiosity, what type of oil did you use and what were your oil change intervals?
Carl Keef Jr
Cedar Park, TX
I had a similar problem on my 2010 Expedition. I thought I was facing an expensive repair until I came across a post from a Ford mechanic with a recommendation that I tried and it resolved the issue completely.
Step 1: Purchase 2 11oz cans of Bg109 Bg EPR Engine Performance Restoration. This will remove all the sludge and clean the solenoid screens.
Step 2: Add the Bg EPR and drive the Expedition for about 15-20 minutes.
Step 3: Let the engine cool and then change the oil and filter using 100% Synthetic 5W-30 motor oil.
I used a FRAM Tough Guard TG2, 15K Mile Change Interval Spin-On Oil Filter and Valvoline Advanced Full Synthetic 5W-30 Motor Oil.
Turns out that everywhere else in the world that Ford sells this engine, they recommend using 5W-30 motor oil. But in the US, to meet emission standards, they recommend 5W-20 oil.
To be on the safe side, I waited about 3 weeks and did this process again. No more issues and I only use 5W-30 motor oil in it now.
Matticus
Salt Lake City
+1 to trying to flush the engine. At this point, if they think you need a new motor, try something like BG oil flush) or whatever else is out there. Personally, I think dealerships just want to sell you a new motor. That seems to be their solution for anything anymore. Broken valve spring? New motor rather than attempt something that takes some intelligence. Engine running rough and you have slightly lower compression on one cylinder compared to the others? We're not going to look any further, so, new motor. Wiper blades not working well? You need a new motor
Goofy173
Ky
First, never take any vehicle to a dealer unless it's warranty work. This from a former Mercury service manager.
So take it to an independent. Ask friends who to go to.
One miss of an oil change will have no effect on build up. I'm not familiar with this engine but I know 5.4s are really susceptible to build-up.
lbv150
Northeast
Kind of like oh he died getting run over by a truck?....list it as COVID19.
lbv150
Northeast
Still waiting on the replay to the oil change interval mileage, type of oil and filter. My '16 and all other vehicles 3,000 max on oil changes and only use the recommended grade of oil, the 3.5 Ecoboost is 5w-30. Oil changes on the 3.5 with the turbo boost is really important. Don't even bother looking at the oil life percent gauge.
rjdelp7
2000 XLT
NY
I suspect the dealer wants no part of working on a vehicle, an owner neglects. Say, they band aid fix it, they know you will be back complaining, when it happens again. A 'new' engine option takes care of that. There is no way to flush an engine. The sludge and debris will go into the pan and get sucked into the oil pickup. When the pick up clogs, you will have no oil pressure. You may find a mechanic willing to clean/replace the VCT solenoid. Detergent in motor oil may clean up the engine slowly, if you do a few oil changes after 1000mi or less. I would try that first or trade it in.
07xln
Dallas
I need to
I need to visit your dealer. From past experience and tons of others I’ve heard from or read about, the dealer does what ever they can to avoid engine replacement. When something clearly warrants an engine replacement they usually wanna tear the motor apart and replace parts and keep the vehicle for months at a time.
