I am getting water in my tail lights, how do you fix this? New tail light? Change the little seal around the light socket?
If it were mine, what I would do is remove the housing, and rotate it around, looking for leaks. If you see water dripping out somewhere other than the socket hole, you have a bad seal or cracked plastic. If not, then it might be dripping down the harness into the housing. Any holes in the roof or tail gate?
Also is it both lights or just one?
Don't back so far down the boat ramp next time.
