What causes "Trailer Disconnected" message?
bmtndog
Northern Colorado
I have a 2015 Ford Expedition with the integrated electric brake controller system. When I connect my small travel trailer and start the engine, I get a message on the info panel on the dashboard "Trailer Connected". (This is always good news.) However, as soon as I start to pull the trailer, I get a message "Trailer Disconnected" along with two "dings". When I slow down to a stop, it reconnects (and "dings" once). As, I accelerate from the stop, I get the disconnected message again. This thing is constantly dinging and telling me the trailer status connected/disconnected/connected/disconnected and is driving me crazy.
The brakes seem to work fine, even when the status is "Disconnected".
I need to get this figured out and fixed.
I've used a tester that has a "trailer simulator" and have no problems. All lights work on the trailer and as I said, the brakes seem to work fine also at all times.
So, I guess I need to know what it is that the truck is detecting that would make it think the trailer is "disconnected"? Then, I can try to figure out what is exciting that failure mode from the trailer (assuming it is not some kind of wiring fault or logic fault in the controlling software on the truck).
Can anyone tell me what is happening when I accelerate that would cause the truck to think the trailer has become disconnected? Any tips on how to troubleshoot this? (The dealer has tested the wiring and say's all seems good.)
Bedrck47
Elizebethtown, PA
check the wiring on the trailer to make sure everything is tight Pay attention to the ground connection on the trailer It almost sounds like you could be loosing a ground between the expy and the trailer
stamp11127
Temple, Georgia
Second on the ground. You can make a short jumper to connect to the tongue and the hitch to test.
When you accelerate, the hitch will move if you are using a receiver type & the ball will move slightly forward in the tongue if not latched tightly. The grease may also cause a loss of ground if overloaded. Some grease is good, gobs of it isn't.
B
bmtndog
Northern Colorado
I will check ground
I bought some wire and alligator clips this week. This coming weekend I'll rig up a jumper between the truck body and trailer body, and will let you know if that makes a difference. I guess the challenge will be finding good connection points.
B
bmtndog
Northern Colorado
Tried grounding experiment with no success
Over the weekend I spent several hours on an experiment to test the grounding hypothesis. I took about 15' of 16 gauge wire with charging clips attached to each end. I connected one end to what seemed like it should be a good ground on the chassis of the truck and the other end to the tongue on the trailer. I did this three times at three different sets of connection points to ensure I was finding a good electrical path to ground.
In all three cases, I still got the "trailer disconnected" message as I accelerated. So, while a very promising hypothesis, good grounding between the truck and the trailer does not seem to be what excites the error message.
Thanks for the suggestion. I'll keep working on this.
B
bmtndog
Northern Colorado
Grounding sounds like such a likely candidate. Is there any way this could be a problem with the truck wiring, such that the control system in the truck is not well grounded to the truck chassis?
I ask because there is one more piece of data for this puzzle. Last May, when the truck was pretty new, we were driving on I80 near Laramie, WY and an error message came up on the info display "Trailer Wiring Fault". We were NOT nor had we ever, up to that point, towed a trailer! I dismissed the warning and it has never occurred again.
While in Laramie, we were staying at our cabin which has "critters". It is not unusual for a pack rat or squirrel to get into the engine compartment and chew on wires.
I see no visible damage, nor did the service techs at the dealership. But, this has me wondering if maybe a wire that grounds the brake control system (including whatever sensing is done to detect the trailer disconnect) is intermittent?
B
bmtndog
Northern Colorado
A quick update on this. I pulled a different trailer with the truck and did not get the Trailer Disconnected error. This seems to narrow the problem to the trailer. However, after about 10 hours of work on this, we can't find anything wrong with the trailer. All wiring is sound. We've tried a variety of grounding schemes and none make a difference. The brakes themselves are in great shape...About to give up and just live with the annoying "ding ding ding" and disconnected/connected message each time I start or stop.
reece146
ON, Canada
Either connector, bad ground or broken wire... not much else it can be.
If it were me I'd probably attempt to fix/replace the trailer side connector and the first 12" or so of wire behind that... if I was convinced that grounding is not the issue.
Bedrck47
Elizebethtown, PA
Don't know if this would make a difference but were the lights LED or Regular lights on the trailer that you have a problem with and what were they on the trailer that gives you no problem
