What Code to Disable Suspension Error Message w/ Forscan After Air to Coil Conversion (2015 EXP Platinum)
PistolPete
NY
Hi All!
I have a 2015 Ford Exp Platinum that I converted from Air Suspension to Coil. The Mechanic did not use Strutmaster or any other brand w/ the Light Out Module. Accordingly I have been driving around with a Suspension Error Code on my dash for the past year. It comes on randomly, and I press OK to clear it.. But within an hour or so it comes back on.
I have Forscan and an OBD2 that supports it...
Is there a code that I can enter in Forscan to eliminate the error message permanently. I do not know what brand coils my mechanic installed but hopefully someone knows the magic way to disable the error code for good despite not knowing brand of coils used.
Would be truly appreciative for any help, guidance, or assistance that can be offered.
Thank you in advance!
Pete
belx
