rob4092xx
I cannot figure out what the “Auto” button with the three small lights above it in the Climate Control does. 2022 Expy with 15” screen. Couldn’t find it in the manual. Any help please? Thanks!
True but auto only affects the fan speeds. Even on a set speed the temp will always be automatic.Auto maintains a set temp inside. The three different settings are the max fan speed. So if you want it quieter when you first get in your vehicle, set it to 1. If you want it to cool/heat as fast as possible regardless of how loud, set it to 3. I leave ours on 2 unless it’s really hot outside. 3 is pretty loud at times.
Depends on what you mean by automatic. In manual mode, the temp of the air from the vents and speed of the fans is fixed based on what you set them to be. In auto mode, the system automatically changes the temp of the air from the vents and fan speeds to reach a desired cabin temp.True but auto only affects the fan speeds. Even on a set speed the temp will always be automatic.
https://www.ford.com/support/how-to...nditioning-and-heating/ford-climate-controls/
