OverlandExpy
Check out some local shops that exclusively work on transmissions/diffs. $4k seems pretty high.
Bang on. What he said.3 valves do make that sound and the plugs do loosen, they have enough threads it won’t blow out like a 2 valve but they make noise. Pull all your COPS. An offending boot will have soot on it and smell like gas. I had 4 come loose. They aren’t torqued down in the back 2 a lot and loosen. FordTechMakuloco has a video on the loosening plugs on the 5.4 3V, almost always after a plug change because a torque wrench wasn’t used. (You can’t use one on a few of them have to go snug by feel). People always mistake it for a rod knock lol.
Should have replaced both axle seals and bearings, while everything was apart, both cheap Items, especially the seals.Found a low mileage differential on ebay from LKQ and got it installed this weekend from a family friend. Noise is gone. NEw ISSUE: fluid is leaking out of the driver side axle shaft hole after I park. Is there a gasket/seal that I should have replaced while it was off? Did they overfill it?
They said they overfilled it, not sure how that is even possible but whatever. I opened the fill port last night and raised one side to drain a little out (I wasn't on level ground). I'll see in the next few days if there is still some leaking out before taking it to a shop.Should have replaced both axle seals and bearings, while everything was apart, both cheap Items, especially the seals.
