drankinatty
All,
Thoroughly enjoyed the [check charging system](https://www.expeditionforum.com/threads/check-charging-system-frustrating-issue.27924/) thread and it ended up leading to finding the GENCOM and GENMON wires frayed and broken about 2" back from the connector where it plugs into the harness about a foot in front of the PCM. Great discussion.
I have a lost vacuum line. Honestly, it's probably been that way for a long time. Likely since the last transmission rebuild. What prompted this find was I just finished the oil pump, timing chains, phasers, etc. where I had removed everything on the passenger side back to the firewall to get the valve cover off. (chains and phasers made it 254K miles before the chain guides disintegrated) During disassembly, I noticed the vacuum line (the line that runs from the booster, up over the back of the engine, is anchored to the back of the air-plenum on the passenger side with a clip, and then disappears over behind the PCM somewhere -- photos below). I thought I'd deal with it during reassembly, but reassembling everything, I still couldn't determine where in the heck that line terminates. Motor runs so smooth and quiet now, I could actually hear the vacuum leak instead of chain slap in the front cover.
The line and where it anchors to the plenum (dog-house, air-box, whatever the air intake is called) is shown in the first attachment, and where it originates on the brake booster is shown in the second photo. I've tried to highlight the line and anchor in yellow to distinguish it - but with limited success. I've searched the charm diagrams to try and find the diagram that shows the routing and connection, but I've had no luck. Does anybody know where line connects (somewhere near the passenger side firewall)? Currently I've just stuck a bolt in it to stop the leak.
Any help would be greatly appreciated.
