Where to ground on 21 Expedition XLT 6 speakers
Redwater
Manitoba
I plan to install Amp and Subwoofer for 21 Ford Expedition XLT 6speakers by myself. But please give me an idea about location to ground when connect Amp with power. Thank you.
Yupster Dog
Super Moderator
Super Moderator
The whole vehicle is a ground so anywhere on metal.
Either find a bolt close to the amp or you can make a new grounding spot with a self-tapping screw. (Make sure you have good ground, remove paint around screw if needed)
Making sure you have the correct gauge wire is also important.
R
Redwater
Manitoba
My expedition is an aluminum frame. Thus I don’t know where I can do that. Thanks
Trainmaster
Old School Member
Rockaway Beach, NY
...and Ford also has a dedicated ground system to most components. Look at a wiring diagram to find which wire on the plugs is ground. Usually it's one of the black ones. Many times the speakers are not grounded, or if they are they are wired to the amp and grounded through the amp.
GGecko311
South East
I've scrapped the paint off before and done the self tapping screw into the body, and also used the seat-bolts.
