I have a 2015 Expy 3.5 EB 2nd with 165k miles one it. A year ago the torque converter started to shutter so I added shudder stop which fixed it this summer. I added it again but when cold it briefly will lose lock up or under heavy load.
So this spring my plan is to drop the trans and replace the torque converter. While I have the trans out, I was planning on replacing the filter, the output flange seal and replacing the already leaking turbo coolant lines.
The valve covers and vacuum pump were already done under extended warranty so that is a few things I should not have to worry about. But what else should I look for or plan on doing while I have the trans out?
